DDR2 Post Translate Simulation
I fail to simulation Post Translate  DDR controller, I Use MIG 2.3  ISE 10.1.03 modelsim 6.3f
Trace the X ,I find the problem is IDDR ,When dq_delayed(It'Clk signal) is X ,the Q1 and Q2 is X,and this make read_data_rise signal is X Which is one of the mig_rd_data_0's port then at 242643850ps data_match_first_clk_rise(singal in mig_rd_data_0) become X then make so many Signal become X
Here is the only Warning I find in Modelsim: At time 206350.0 ps,  WREN on X_FIFO16 instance sim_tb_top.u_mem_controller.\main_00/top_00/user_interface_00/backend_fifos_00/wr_data_fifo_160/Wdf_1  is high when RST is high. WREN should be low during reset. But I don't think It make DDR2 Controller failed.
Do you have any problems with behavioral simulation? Structural simulations are not supported with MIG designs so there are likely road blocks with the models or netlists you will encounter.
