lilia20190227
DDR3,ECC
I'm looking to implement ECC with a design using DDR3.According to UG586,ECC is enable only for 72-bit. But the ddr3 memory which I use only has 16-bit width data bus. Is this contradict?
rpr
Hi @lilia20190227
Xilinx MIG supports ECC over 72 bit width, doesn't support with 16 bit and  other bit width.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
lilia20190227
The ddr3 memory which I use only has 16-bit width data bus. And I shall implement ECC. What should I do in hardware?
kshimizu
Hello @lilia20190227 ,
It needs 72bits if you want to use the ECC.  It describes in the UG586, hence we can not provide how to use the ECC with 16bits.
Best regards,
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
lilia20190227
How I connect several 16-bit ddr3 memory in parallel to make 72-bit ?
greatmaverick
I have searched  Micron DDR3 products, no 72 bits DDR3 exists. 16 bits is the largest width. How can I use 72 bits DDR3?
