raghavs
DDR3 Interface Pin Mapping File for Digilent Genesys2 Kintex7 FPGA
Sorry that I am not able to sign up on digilent forum because of their website issues. The below link says, they suggested to used fixed pin-out for DDR3 interface mapping to FPGA pins. If anybody has link, for genesys2 Kintex7, Can you please share?
I used the option of letting tool do the mapping and it seems not working on FPGA.
https://forum.digilentinc.com/topic/4035-genesys-2-board/
The MIG Wizard will require the fixed pin-out of the memory signals to be entered and validated before generating the IP core. For your convenience an importable UCF/XDC file is provided on the Digilent website to speed up the process.
thank you in advance,
rpr
Hi @raghavs
Few Eval boards XDC also available over github.com.
https://github.com/Digilent/Genesys2/tree/master/Resources/XDC
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
raghavs
Hi Pratap,
Thank you.
Hmmm. This XDC file contains many peripherals but NoT  DDR itself.
Please let me know if I am missing something.
I used some file from other project . But ended up with DRC error of partially routed nets on 4 nets of ddr phy lanes. I have reduced DDR frequency by half that is clock period of 2500 ps, still same issue. The design was working fine with MIG 7series controller without axi interface . Now I needed axi based MIG controller. I followed digilent reference manual to configure MIG.
Do you have any suggestions , please ? I had worked in asic before but working on fpga for first time .
Raghav
