DDR3 Interface
I have used 8 bit DDR3 in one of my production and now am shifting to 16 bit DDR3.
will it cause any thermal issues if we are switching from 8 bit to 16 bit DDR.
Appreciate your quick response!
Sachith
Hi @sachith
i believe there wont thermal issue however  make sure that what was thermal analysis you did for x8 you follow for x16 too.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
