akarshana
DDR3 memory banks with system clock bank selection
hi we are using virtex-7 and airtex-7 in our customised board. For these 2 FPGA's we are interfacing DDR3 memory. Banks selection for address lines, data line and control lines are fine . But I have studied in MIG controller data sheet, system clock should be given to the bank that is same in DDR3 address/control lines bank. Because of voltages issue it's not possible to given the system clock to same bank. So can I  use another bank mrcc pins to system clock? Or it is must be same bank
Please suggest me to proceed our design further
kren
The clock input can be input on any CCIO in the column where the memory interface is located; this includes CCIO in banks that do not contain the memory interface, but must be in the same column as the memory interface.
-----------------------------------------------------Please don't forget to give kudos or accept as solution if information provided is helpful.---------------------------------------------------------------------
