DDR3 placement and route error for artix 7
I am trying to run DDR3 (IS43TR16256A-125KBLI) on custom board with Xilinx Artix 7 200T FB676 on Xilinx ISE 14.5. I am able to generate MIG core successfully. I am using complete Bank35 same as Nexys video card but with different LOC names. nexys video pin schematic is shown in image.jpg
I wrote a top wrapper of MIG core XCO file, with simple logic of reset going high and low to check if calibration is done or not on board. Simulation, synthesize, translate, map all works fine with warnings. But PAR gets error, and error is
ERROR:Route:471 -
   This design is unrouteable. Router will not continue. To evaluate the problem please use fpga_editor. The nets listed below can not be
   routed:
Unrouteable
Net:u_mig_core/u_memc_ui_top_std/mem_intfc0/ddr_phy_top0/u_ddr_mc_phy_wrapper/u_ddr_mc_phy/ddr_phy_4lanes_0.u_ddr_phy_4lanes/phaser_ctl_bus<0>
Unrouteable
Net:u_mig_core/u_memc_ui_top_std/mem_intfc0/ddr_phy_top0/u_ddr_mc_phy_wrapper/u_ddr_mc_phy/ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_C.ddr_byte_lane_C/ddr_byte_group_io/tbyte_out
Unrouteable
Net:u_mig_core/u_memc_ui_top_std/mem_intfc0/ddr_phy_top0/u_ddr_mc_phy_wrapper/u_ddr_mc_phy/ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/ddr_byte_group_io/tbyte_out
Unrouteable
Net:u_mig_core/u_memc_ui_top_std/mem_intfc0/ddr_phy_top0/u_ddr_mc_phy_wrapper/u_ddr_mc_phy/ddr_phy_4lanes_0.u_ddr_phy_4lanes/phaser_ctl_bus<2>
Unrouteable
Net:u_mig_core/u_memc_ui_top_std/mem_intfc0/ddr_phy_top0/u_ddr_mc_phy_wrapper/u_ddr_mc_phy/ddr_phy_4lanes_0.u_ddr_phy_4lanes/phaser_ctl_bus<7>
Unrouteable
Net:u_mig_core/u_memc_ui_top_std/mem_intfc0/ddr_phy_top0/u_ddr_mc_phy_wrapper/u_ddr_mc_phy/ddr_phy_4lanes_0.u_ddr_phy_4lanes/in_rank<7>
Unrouteable
Net:u_mig_core/u_memc_ui_top_std/mem_intfc0/ddr_phy_top0/u_ddr_mc_phy_wrapper/u_ddr_mc_phy/ddr_phy_4lanes_0.u_ddr_phy_4lanes/in_rank<6>
Unrouteable
Net:u_mig_core/u_memc_ui_top_std/mem_intfc0/ddr_phy_top0/u_ddr_mc_phy_wrapper/u_ddr_mc_phy/ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/po_rd_enable
When I open FPGA editor and try to execute command route –all again same error generates.
How to resolve this problem same problem goes with Nexys video Kit. Attach is synthesis, translate, map, place and route reports with parameter setting.
Tags (4)
Re: DDR3 placement and route error for artix 7
Hi @maheen_189
You need to regenerate the mig ip if you want to change any DDR3 pin locations.
You can use "verify pin changes and update design" flow in mig ip where you can source the mig .prj and updated .ucf files.
Deepika.
I have already done that, issue is not pin locations. MIG verify pin changes gives all ok. problem is PAR error mentioned above
Hi @maheen_189
You should generate the mig with new pinout and use the newly generated mig ip. Have you done that?
If you use old ip with new pinout you will run in to errors like this one.
Deepika.
Yes i have done that with pin configuration as per "XC7A200TFBG676" Bank 35 pins. even i make clean project with these pins from very start.
@vemulad All generation regeneration is done, but issue exist. I even try new project for Nexys video kit but issue is same. difference between custom board and Nexys video kit is: custom board FPGA is XC7A200TFBG676 while Nexys video kit FPGA is XC7A200TSBG484. means PIN LOC different. I created two different projects for both of them
Hi @maheen_189
Please share the below files
mig xco
mig prj
.ncd
Deepika.
hey sorry for late reply. attached is complete project. can you find problem and resolve it and hen send it back to me.
thanks
@vemulad no update ???? i am waiting for your response
