esakki@babu
DDR3_test and Debugg
In Kintex KC705
I tried to access DDR3 memory by  IP catalog and IP integrator.
What is the purpose of Traffic Generator in MIG?
I want to send arbitrary data or receive data from UART to store into DDR memory. Please help me this.
Esakki
rpr
Hi esakki@babu
MIG IP provides an example design. Traffic generator use are seeing is related to example design.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
esakki@babu
Hi Pratap @rpr ,
Is it possible to make custom MIG IP For custom design? How to refer for custom MIG IP?
Thanks & Regards
Esakki
rpr
Hi esakki@babu
Are you looking for a custom memory part? refer to https://www.xilinx.com/support/answers/63462.html
But if you are looking to customize MIG IP then generate IP output products in Global and edit as per your requirement.
Pratap
