billypowell
DDR4 4 x 16Gb components data error above address 2048
I'm developing a custom board based on a Kintex Ultrascale xcku040 FPGA. I have implemented two independent DDR4 MIG controllers. Each controller is connected to four 1Gx16b Micron components MT40A1G16KNR-075 running at 1200MHz (2400 MT/s) to obtain a 64 bit-wide bus.
The self calibration of both the controllers always pass with a good margin and no warnings.
When I try to read or write to the DDR4, each operation that involves the first 2048 addresses (I mean  0 <= app_addr < 2048*8) works fine. When I try to write a bigger portion of the memory and read it back, most of the data read are corrupted.
Both controllers show the same behaviour.
I also tried to slow down the speed of the controller, but the result is the same.
What could be the problem?
Thank you in advance.
bp
billypowell
I solved the problem by installing the last Vivado version (2019.2) and by recompiling the project.
Now it seems to work fine.
bp
billypowell
bp
