ultrascaleaddict
DDR4 Clamshell Topology and Write Leveling
Is write leveling also handled when having a clamshell topology or is it only available for fly-by architectures as mentioned in PG150 (DDR4 SDRAM feature summary page 12)?
I can't find any information regarding this feature for clamshell.
Thanks in advance for any hint.
rpr
Hi @ultrascaleaddict
Fly by and Clamshell are routing topologies, irrespective of routing topologies i.e., even if there is single DQS and DQ byte group then also the write leveling exist.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
kren
The write leveling is handled in both fly-by and clamshell topology.
-----------------------------------------------------Please don't forget to give kudos or accept as solution if information provided is helpful.---------------------------------------------------------------------
ultrascaleaddict
Hello and thanks for the answer.
Is it mentioned somewhere? In some document ou application note for instance
rpr
Pratap
