Participant walidhendrix
DDR4 Clock sharing
Hello to everyone,
So I am targeting a KU060 and I need to use one differential system clock for both MIGs.
- I am using Vivado 2018.3
- I have a block design including a MIG instance (with teh famous "No Buffer" option selected)
- The block design is instantiated twice, one for each memory group
- System clock is on bank 44
- Memory group 1 is on banks 44, 45 and 46
- Memory group 2 is on banks 66, 67 and 68
- The clock path is : GCIO -> IBUFDS -> BUFG -> each MIG instantiation (I also tried the IBUFDS output for Group 1 and BUFG output for Group 2 but with no success).
- The BACKBONE constraint is in my xdc file:
set_property CLOCK_DEDICATED_ROUTE BACKBONE [get_pins -hier -filter {NAME =~ */u_ddr4_infrastructure/gen_mmcme3.u_mmcme_adv_inst/CLKIN1}]
- I keep having the same error (see attached image)
Thank you in advance for any hint.
Tags (4)
Re: DDR4 Clock sharing
As the two DDR4 controllers are not in the same column, it's sugggested to use separaterd system clock input in each column.
first of all, test your block design one by one. comment the other one and test DDR MIG on board. you will find your problem in a better way, as it seems from your error you will not pass the test in one by one test scenario.
OK, so I tested the design one by one (even thoug I was sure about the result) and it gave what I expected:
- No problems when using the block dersign with the memory group 1
- Error with the memory group 2 (since not on the same column as the system clock)
your DDR clock must be placed on any GCIO pin pair in the same column as that of the memory interface. If you want to share the system clock input between two memory interfaces then both of the memory interfaces should be in the same IO column and in the same SLR.
