zxm02370303
DDR4 MIG Calabration down
HI Dears,
i wonder if there are any possibility that the ddr4 mig with axi interface will pass calabaration after reset but calabration got to 0x0 after may be several minutes.
It is UV440 device and vivado2018.2 64bits software and MIG configure with axi interface without ecc, reference clock 200Mhz and memory device interface with 800Mhz on a MICRO MTA18ASF1G72PDZ RDIMMs.
Thank you.
kshimizu
Hello @zxm02370303 ,
I don’t have any ideas now.  What I am thinking is to try an example design.  It’s better to conduct tests with simple design, so please remove your other modules if there are, and then try to watch what it will be.
Best regards,
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
