DDR4
DDR4 RDIMM: DQ and DQS lines alignment on PCB
Dear Community,
I couldn't find a clear answer in the documentation on the question: shall the data within a byte be aligned for
DDR4 RDIMM design, if 2 DQS signals are presented for a single byte? (x4)
Let's assume, I'm using x4 memory module controller, like M393A8K40B21-CTC.
Will it work, if tetrads are not aligned within a byte?
Please, advise.
kren
The skew requirement it for DQ(Data) to associated DQS. In your case, it should the 4 bit data to the associated DQS.
-----------------------------------------------------Please don't forget to give kudos or accept as solution if information provided is helpful.---------------------------------------------------------------------
kren
DDR4
Thank you @kren
