Visitor juweld
DDR4 SDRAM MIG Simulation failure
I have tried to run behavioral simuation with example_design of DDR4 SDRAM external memory interface for "PHY only configuration".
But I am getting the below error.
 # log_wave -r /
# run 1000us
FATAL_ERROR: Vivado Simulator kernel has discovered an exceptional condition from which it cannot recover. Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.
Time: 0 ps Iteration: 0 Process: /sim_tb_top/mem_model_x8.memModels_Ri1[0].memModel1[0].ddr4_model/_state/Initial11_125723
Can anyone help to solve it?
Visitor juweld
Re: DDR4 SDRAM MIG Simulation failure
Hi Calebd,
Thanks for your response. I have debugged the reason behind it.
I am able to run the simulation with below change to my vivado tool settings..
1.simulation language->mixed
   Its one of the reason(previously I had kept it as verilog by mistake) why calibration was not happening and tb was hitting an infinite       wait state.
thanks
Juwel
Hello @juweld
That error makes me believe something in your environment or tool is having an issue.  This isn't really related to the MIG itself.  Have you been able to reproduce the issue (tried to run the simulation again on the same project)?  Could you go to your user data and delete a folder titled .Xil or .Xilinx and then try again?
Caleb
Visitor juweld
Hi Calebd,
thanks
Juwel
