akhtar2510
DDR4 clk to DQS Skew
I want to simulation Kintex ultrascale  and DDR4 in Hyperlynx . After simulation , Read ,Write , Address and diffrencial pairs are OK, but i have problem in clk to DQS Skew.
I must be change track size of lane  or set delay in lane pins.
can i set delay for pins ?
how can i solve clk to DQS skew problem ?
please help me
deepalir
Hi @akhtar2510
The general guideline and requirement is CK/CK# must arrive after DQS/DQS# at each memory component to ensure calibration can align DQS/DQS# to the correct CK/CK# clock cycle. The Ultrascale device memory controller can internally delay the DQS line to account for negative skew.
Please refer to UG583 -General Memory Routing Guidelines section, skew constraints range and trace lengths for more information.
deepalir
Hi @akhtar2510
watari
Hi @akhtar2510
Did you consider the following typologies to resolve DQS skew issue ?
- Fly-by topology
- Clamshell topology
Best regards,
kshimizu
Hello @akhtar2510 ,
Xilinx does not support any changes in the IP.  As @deepalir mentioned, memory controller adjust the delay based on the FPGA package delay and PCB skew.  Please check the PCB guideline and routing.
Best regards,
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
akhtar2510
Thank you
