DDR4 command/address/clk routing between VDD and Ground planes
If the impedance is correct, is there a problem with routing DDR CAC signals between power and ground planes ?
Emmett
Yes, you can refer to the "reference stackup" section in ug583: https://www.xilinx.com/support/documentation/user_guides/ug583-ultrascale-pcb-design.pdf
-----------------------------------------------------Please don't forget to give kudos or accept as solution if information provided is helpful.---------------------------------------------------------------------
Hi kren,
I saw that before, but the innermost signal layer is between GND and PWR/GND.
That could mean the power might be VDD of the DRAM or that it must be GND.
Don't want top assume anything.
Emmett
Hi @ebradford
Its depends on routing topology, for example fly-by routing or clamshell topology.
Detailed information is documented in ug583, link provided below
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
