liebejo77
DDR5 PHY IP of xilinx is available?
We are trying to synthesize the ddr5 controller on the FPGA.
But I want to know if xilinx supports ddr5 PHY IP.
If not possible, we would like to try FPGA synthesis using xilinx's ddr4 PHY IP.
Please let me know if xilinx ddr4 PHY IP supports the DFI standard interface, so I can connect with the customer's ddr5 controller.
kshimizu
Hello @liebejo77 ,
Xilinx does not have DDR5 IP for memory interface.
Best regards,
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
