chlwogns414
Data conversion using MIG
I am trying to control DDR memory by MIG.
The final Goal is that FPGA get 16 bit ADC data and write data to app_wdf_data(128 bit).
I was wondering how to make data. I thought one idea like below.
1. write
After writing data, I have to read data and send it to MCU using EIM.
When I read data from DDR is it possible to make data like below?
2. read
Timing chart seems to be poor. I want to know that it is possible to make interface like picture.
If I can't, could you share Idea to make interface to achieve my Goal?
Thank You.
kren
I suggest you create a user FIFO when comunicating with the MIG user interface. You can refer to pg150 (https://china.xilinx.com/support/documentation/ip_documentation/ultrascale_memory_ip/v1_4/pg150-ultrascale-memory-ip.pdf) for details on the user interface timing.
-----------------------------------------------------Please don't forget to give kudos or accept as solution if information provided is helpful.---------------------------------------------------------------------
kren
kshimizu
Hello @chlwogns414 ,
What you mention is one of way.  Please inputs your data to user_interface(MIG) as shown in Figure4-2, -3 and -4 in PG150.
https://www.xilinx.com/support/documentation/ip_documentation/ultrascale_memory_ip/v1_4/pg150-ultrascale-memory-ip.pdf
An example simuation is also possible, so please try it to ensure your idea.
Best regards,
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
