Newbie olsene01
Does successful MIG calibration completely validate PCB design?
I am working on a new PCB design that includes a DDR3 interface to a xc7k325tffg676-2 FPGA. I have a test bitfile with a MIG and the MIG init_calib_complete signal is asserted a few seconds after boot. Since we are under a deadline to do a board respin and there are other peripherals to validate, does a successful calibration verify that the PCB layout and design is valid? Are there other things I should do before saying this part of the PCB is working?
Scholar drjohnsmith
Re: Does successful MIG calibration completely validate PCB design?
Basically, its a good start, but nope,
You can not "prove" a PCB design by running a random sample of one,
Things like DDR interfaces, you need to simulate, using tools like HyperLynx.
If you can not simulate, at least get a memory test running, thrashing the design, and leave it for a few days... If you have a means to cool and heat the board, be it a hot water bottle with hot or cold water or a proper chamber, all the better.
You still have not worst case proved, but your going to get a better confidence level.
You need to run a memor
y test,
Newbie olsene01
Thanks. Is there a recommended method for testing, assuming I cannot simulate? Would an AXI Traffic Generator suffice?
Scholar drjohnsmith
Any pattern generator will do, some more than others,
You just need to be able to check the data is written and read correctly,
some sort of PRBS to generate data and a state machine to check results
Or have search for tools on line
