raghavs
ERROR: [DRC RTRES-1] Backbone resources: 1 net(s) have CLOCK_DEDICATED_ROUTE set to BACKBONE but do not use backbone resources. The problem net(s) are
My Design was working fine with mig_7series (Without AXI).
Now, I needed mig_7series (with AXI) based memory controller.
I have attached mig_7series_axi4 configuration that was used to generate using MIG wizard.
I am using Vivado 2018.2. and Digilent genesys2 board.
I see below error during implementation. Can you please give me a hint to solve this?
ERROR: [DRC RTRES-1] Backbone resources: 1 net(s) have CLOCK_DEDICATED_ROUTE set to BACKBONE but do not use backbone resources. The problem net(s) are chipset/clk_mmcm/inst/mc_sys_clk
In above message, mc_sys_clk is connecte to both "sys_clk" and "ref_clk" at mig_7series_axi4 instance.
Thank you!,
Raghav
kren
There will not be any functional problem.
-----------------------------------------------------Please don't forget to give kudos or accept as solution if information provided is helpful.---------------------------------------------------------------------
yangc
please refer to https://forums.xilinx.com/t5/Implementation/DRC-RTRES-1-Backbone-resources-1-net-s-have-CLOCK-DEDICATED/m-p/1042044 to have a try.
raghavs
I set it to CLOCK_DEDICATED_ROUTE set to FALSE to avoid error, NOT sure if it creates any functional issues.
I will update here later.
Raghav
kren
