ERROR [IP_Flow 19-98] and [IP_Flow 19-3505]
I have purchased a board ZCU106 Eval kit.
So i have redeemed the license comes with the kit, Vivado design suite.Can't I generate and use these IP cores with this license.
Now i am trying to generate an ip for DMA application. Its showing me following error during synthesis.
[IP_Flow 19-3505] IP Generation error: Failed to generate IP 'dmac_dma_ctrl_top_0_0'. nullptr IP data detected.
[IP_Flow 19-98] Generation of the IP CORE failed.
Failed to customize IP 'dmac_dma_ctrl_top_0_0'. IP customization unsupported or disallowed.
Please help me out. I need urgent suggestions.
Re: ERROR [IP_Flow 19-98] and [IP_Flow 19-3505]
HI @venugopal.kulkarni
Where is the dmac_dma comming from?
Is it from the vivado IP catalogue?
It looks to be from ADI (https://wiki.analog.com/resources/tools-software/linux-drivers/axi-dmac)
Florent
yes it is from ip
please follow this link:
this is the board in which i want to access DDR4 RAM.
If the IP is from Analog devices then I encourage you to ask them directly. I might be that the vivado version you are using is not supported by the IP
I am confused. You said that you are using the ZCU106 at the beginning and now you are mentioning another board
Florent
Ya the board i mentioned later is the exact board.
TE0803 04CG-1EB by Trenz.
