Example design of DDR4 IP has timing failures on Kintex UltraScale Device
I have generated the example device by right-clicking on ddr4_0.xci. Then I synthesized the design and clicked on report timing summary. Unfortunately, Hold Slack (WHS and THS) is failing for the example design. I am using Vivado 2019.2 and I implemented the design on Kintex xcku060-ffva1517-1-c (active) device. I have attached all the screenshots of how I configure the DDR4 IP, timing summary, failing paths and timing report
Koshila
timing.rpx file is attached here
Hello @koshilagimhanis ,
I could not find out the same error you pointed out.  I created an example design based on your settings.  Could you please try to create an example design only.
Best regards,
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
