anupkini
HBM IP example design with QuestaSim, read not working
Hi All,
I am trying to build a design for XCVU37P-2 with HBM IP., Single Stack, no parity, using QuestaSim 10.7.
While running simulation, thre read address are accepted, but the read data (rvalid signal) is never received.
Kindly let me know if anyne has faced similar issue and how to proceed further.
Anup.
coryb
Hello @anupkini,
Please look into the following AR to get Questasim working with the HBM Example Design: https://www.xilinx.com/support/answers/71097.html
Let me know if this does not solve your problem.
Cory
coryb
Hello @anupkini,
Cory
