HBM Simulation Backdoor
Hi Xilinx,
I'm using HBM example design to simulate. Everything works well but could you please provide a backdoor way so that I can force data directly to the sim HBM without writing through AXI port? This will help us to initial the HBM with some value.
the backdoor should have this format : // HDL_PATH  : + ...hbm_0.inst.u_hbm_top.hbm_two_stack_intf.hbm_mem_rt.mem[index]
Many thanks.
Hello @haiphongpham1995,
I have contacted Samsung to see if they have a solution that they can provide us. Currently we do not have a way to pre-load data into the HBM model without the AXI Interface.
Cory
hi @coryb,
Thank you very much for your support. So we'd better wait now. Let me know if you get any information from SamSung.
Many thanks
Hi @coryb,
any information from Samsung yet?
thanks
No I have not heard anything. I do not think a simulation backdoor exists. The AXI Interface is required to populate the DRAM contents.
Cory
Does anyone know if there were any actions being taken to change this or if Samsung has provided to you directly?
Really, i don't think Xilinx can consider themselves a serious memory vendor without this ability.
