hankchen
HBM access show "decode error"
1. Platform : VCU128
2. Configuration : 4GB, select LEFT
3. When I do "AXI write" by address = 33'h0_0000_0008, I find the "BRESP = 3". Then, the content of "AXI read" is wrong.
     I check from AXI protocol, "BRESP = 3" means "DEC error".
     Based on the description of pg276 document, 33'h0_0000_0000 should be the range of HBM MC0.
     The following waveform is captured by ILA.
kshimizu
Hello @hankchen ,
I’m no sure what occurs on the VCU128 form your ILA.  The first step is to compare between simulation and ILA.  Please try to do simulation with your addressing.
Best regards,
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
hankchen
Can I check by inserting ILA directly ?
kshimizu
Hello @hankchen ,
I’m not sure what you mentioned.  Is your previous waveform captured by ILA?  I think it would be better to compare between ILA and simulation.
Best regards,
Kshimizu
hankchen
Yes, the waveform is captured by ILA. All of the signals are connected with HBM module directly. Is it necessary to show all the waveform of HBM ports ?
