How can I control 2 DDR2 modules in 1 FPGA chip by using MIG IP core?
I use XC5VLX220-1FF1760, MT4HTF3264HY-53E, ISE v12.1, MIG v3.4.
I choose multicontrollers 2 in one MIG to control 2 MT4HTF3264HY-53E modules ( in one FPGA chip ) , and thus it generates 2 groups of user application signals and memory device signals.
I found clk0_tb, rst0_tb and ddr2_reset_n signals public used.
Can I control 2 MT4HTF3264HY-53E modules in the way above ?
If can't ? How can I do ? Thanks !
Yes, the two DDR2 controllers are independent. You can modify the source code and get clk0_tbrst0_tb and ddr2_reset_n signals driven by differential signals.
-----------------------------------------------------Please don't forget to give kudos or accept as solution if information provided is helpful.---------------------------------------------------------------------
Oh, thank you very much!  :smileyhappy:
Can I use two IP cores to control partly two DDR chips ?
And comparing with my first method, which is better ?
But I meet a problem that I can't solve ( using my first method ( one IP Core control two DDR2 modules ) ):
ERROR:LIT:600 - IOBUFDS symbol
   "u_ddr2/u_ddr2_top_0/u_mem_if_top/u_phy_top/u_phy_io/gen_dqs[0].u_iob_dqs/gen_dqs_iob_ddr2.u_iobuf_dqs" (output
   signal=u_ddr2/u_ddr2_top_0/u_mem_if_top/u_phy_top/u_phy_io/gen_dqs[0].u_iob_d
   qs/dqs_ibuf) does not have IOSTANDARD specified. Map is unable to generate a
   default IOSTANDARD for IOBUFDS, one has to be explicitly provided.
How can I solve this prolem?
I am having the same error that you had. Did you solved it?
   "DDR2_SDRAM/DDR2_SDRAM/u_ddr2_top/u_mem_if_top/u_phy_top/u_phy_io/gen_dqs[0].u_iob_dqs/gen_dqs_iob_ddr2.u_iobuf_dqs" (output
   signal=DDR2_SDRAM/DDR2_SDRAM/u_ddr2_top/u_mem_if_top/u_phy_top/u_phy_io/gen_d
   qs[0].u_iob_dqs/dqs_ibuf) does not have IOSTANDARD specified. Map is unable
   to generate a default IOSTANDARD for IOBUFDS, one has to be explicitly
   provided.
Instructor
Instructor
The simple answer is to use Planahead (or edit .UCF manually) to specify an IOSTANDARD parameter for the DQS output diff pair.  It should be the same as for the DQ pins.
- Bob Elkind
SIGNATURE:
Summary:
I have tried to may my design  with DDR2 modules into a V5LX50T FPGA using ISE 12.3. However I get the following error:
Error: LIT 600 - IOBUFDS
 "Inst_system/DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_v5_ddr2_phy.mpmc_phy_if_0/u_phy_io_0/gen_dqs[0].u_iob_dqs/gen_dqs_iob_ddr2.u_iobuf_dqs"
(output signal=
Inst_system/DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_v5_ddr2_phy.mpmc_phy_if_0/u_phy_io_0/gen_dqs[0].u_iob_dqs/dqs_ibuf)
does not have IOSTANDARD specified. Map is unable to generate a default IOSTANDARD for IOBUFDS, one
Errors found during logical drc.
Design Summary
I have tried to edit the .ucf file manually and set the DQS pins with the same parameter as that of the DQ pins, but no use. Could anyone let me know as to how can I figure out this problem.
Instructor
Instructor
Vijay,
Your problem seems to be the same as the original post's example.  The suggested remedy is the same as well.
Specify the proper IOSTANDARD for the IOBUFDS package pins.  You can do this by either manually editing the .UCF file for your design, or use the PLANAHEAD tool to make the changes.  The proper IOSTANDARD for differential DDR2 signals is DIFF_SSTL18_II.
-- Bob Elkind
SIGNATURE:
Summary:
I'm fairly new to FPGAs and I want to make sure I understand this.
I had this exact same error.
but my UCF file had theses lines in it :
NET  "ddr2_dqs[*]"                              IOSTANDARD = DIFF_SSTL18_II_DCI;
NET  "ddr2_dqs_n[*]"                            IOSTANDARD = DIFF_SSTL18_II_DCI;
which sounds like your answer - no ?
I got past the problem by adding the IOSTANDARD line to the code in ddr2_phy_dqs_iobs.v file :
  generate
    if (DDR_TYPE > 0) begin: gen_dqs_iob_ddr2
      IOBUFDS #
         .IOSTANDARD ("DIFF_SSTL18_II_DCI")
        u_iobuf_dqs
         .O   (dqs_ibuf),
         .IO  (ddr_dqs),
         .IOB (ddr_dqs_n),
         .I   (dqs_out),
         .T   (dqs_oe_n_r)
    end else begin: gen_dqs_iob_ddr1
      IOBUF u_iobuf_dqs
         .O   (dqs_ibuf),
         .IO  (ddr_dqs),
         .I   (dqs_out),
         .T   (dqs_oe_n_r)
    end
  endgenerate
 I'm not crazy about this solution and would appreciate a better approach to fixing the error.
Thanks in advance.
Martin
P.S.
I doubt these particulars matter for this question, but will include them just in case.
I used MIG  3.61.
Target FPGA is Virtex 5.
FPGA : xc5lvx110-ff1153
UDIMM - MT4HTF3264AY-667
i often meet the same poblem
when i meet this problem i will rebuild a new project and maybe this problem don't appear again
Where did you find this file?
