xifengw
How to Use both HBM and DDR on the VCU128 board
Hello
I tried to use DDR and HBM at the same the on vcu128 board,The message indicates an error in the constraint file for DDR, but the file is read OnlyI tried the solution for this page
https://forums.xilinx.com/t5/%E5%AD%98%E5%82%A8%E6%8E%A5%E5%8F%A3-%E8%A7%86%E9%A2%91/%E5%9C%A8VCU128%E5%90%8C%E6%97%B6%E4%BD%BF%E7%94%A8HBM%E4%B8%8EDDR/m-p/1126319/highlight/false#M1335
The IP setting and  logs are below. Please tell me the correct way to build IP.
xifengw
logs are shown in pic 2
kshimizu
Hello @xifengw ,
The output from clk_wiz is connected to the DDR4(MIG) in your design.  The MMCM output is not used as the sys_clk in DDR4(MIG).  System clock needs to use the GCIO pin.
Attached is from the PG150 which describes the MIG.
https://www.xilinx.com/support/documentation/ip_documentation/ultrascale_memory_ip/v1_4/pg150-ultrascale-memory-ip.pdf
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
xifengw
