tomray
How to avoid the initialization process when simulating with DDR3 MIG memory interface ?
In my design, I need to access three independent DDR3 memory chips.
I generate three DDR3 controller using MIG 7 Series 1.6.
It seems to take about 50us time to wait until the init_calib_complete is 1 that my design can work.
It’s a long time to wait and I can’t bear.
Could anyone tell me how to avoid the initialization process while simulating? Or how to accelerate this initial stage ?
vsrunga
Unlike 6 series you cannot bypass entire calibration for 7 series.
Please check if SIM_BYPASS_INIT_CAL set to FAST and it is what all can be done for 7 series.
I hope 50us simulation time is common to assert init_calib_done.
if in case you are using ISIM/XSIM try in modelsim/questasim.
FurtherMIG 1.6 might be having many known issues, so I would sugget you to upgrade your tools and IPs for reliable results.
http://www.xilinx.com/support/answers/54025.html
Hope this helps
Vanitha
