How to disable dbg_hub when using MIG
HI,
I am using MIG DDR3 in my design, but I found each time the tool will add a module named as dbg_hub, how to disable it?
@jeffson You can't since the XSDB which is always used in MIG IP (in Ultrascale family) requires it. Below is the AR that explains it
https://www.xilinx.com/support/answers/63103.html
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
- Giri
