Visitor panfei
How to let MT18JSF51272AZ-1G4 run on 400MHz
Hi, everyone
 I am using the MT18JSF51272AZ-1G4 (DDR3-1333, 4GB, Dual Rank, EEC enabled UDIMM) on  xc6vhx380t-2ff1923. But the MIG3.92 only support 303.030MHz. How can I make it run on  400MHz?
Thanks!
Re: How to let MT18JSF51272AZ-1G4 run on 400MHz
You can adjust the MMCM multiply/divide values to achieve the 400MHz output clock. The following parameters will need to be changed in the top-level RTL file:
parameter CLKFBOUT_MULT_F = 16, // write PLL VCO multiplier.
parameter DIVCLK_DIVIDE = 8,          // write PLL VCO divisor.
parameter CLKOUT_DIVIDE = 2,        // VCO output divisor for fast (memory) clocks.
parameter nCK_PER_CLK = 2,          // # of memory CKs per fabric clock.
        // # = 2, 1.
parameter tCK = 1875,
