tomray
How to modify the certain word in one write burst operation?
In my experiment, the UI Data Width = 512 bit, the memory is distributed as:
address 0(the first burst):  [D0 D1 D2 D3 D4 D5 D6 D7]
address 8(the second burst):[E0 E1 E2 E3 E4 E5 E6 E7]
the width of word Di (i = 0,…,7) is 64 bit。
Now I want to modify the word D0 to A0,so I set the user interface as follows:
app_en = 1;
app_cmd = 3’b000;
app_addr = 0; // the address is alignment for burst 8
app_wdf_data = [A0 X X X X X X X];
app_wdf_mask = 0x00_ff_ff_ff_ff_ff_ff_ff;
app_wdf_wren = 1;
app_wdf_end = 1;
Now the question is: if I want to modify the word D1 to A1, then how to set the user interface above. I set the user interface like this:
app_en = 1;
app_cmd = 3’b000;
app_addr = 1; // this address is not alignment for burst 8
app_wdf_data = [X A1 X X X X X X];
app_wdf_mask = 0xff_00_ff_ff_ff_ff_ff_ff;
app_wdf_wren = 1;
app_wdf_end = 1;
Is this correct ? Could anyone give me some advice ?
vsrunga
Yes if you want to just mask words within a UI width/ memory burst yes you just need to assert the mask signal correctly, app_addr remains the same for that specific address
vsrunga
App_wdf_mask = 512/8 = 64,  so each mask byte implies one user word
Assuming your D0 corresponds to Zeroth word, D1  first word and so on...
App_wdf_mask Bits [0:7] corresponds to D0
App_wdf_mask Bits [15:8] corresponds to D1
So you have to set app_wdf_mask = 0xff_ff_ff_ff_ff_ff_ff_00;  to write only D0  and mask other words similarly
you have to set app_wdf_mask = 0xff_ff_ff_ff_ff_ff_00_ff;  to write only D1  and mask other words.
You can run a quick simulation and compare written and read datas for confirmity.
Hope this helps
Vanitha
tomray
How about app_addr ?
It's the same for write D0 and D1 ?
For the words in the same burst, the app_addr is not needed to be modify ? Just modify the app_wdf_mask ?
vsrunga
