How to perform read and write to pl ddr
hi,
i have created a design for 5ev-1 with 1 gb pl ddr .the address editor shows 8000_0000 as starting address and high address is 9fff_ffff.
when i use wr or wd or mtest command in uboot ,the cpu resets itself.read and write to this address is not possible.
what is the reason ?and how can i read and write to pl ddr?
V
Observer praful.r
Re: How to perform read and write to pl ddr
Are you able to solve that issue? I am also facing the same issue.
hi @praful.r
I havent found the solution yet .Are you facing the same issue too?
Are you using reference board?
Observer praful.r
Hi @veekshitha ,
I am using custom board. I have tested the same with ZCU106 reference board. In the reference board, i am not getting this error.
Praful
hi @praful.r
how did u perform the test for zcu106?
could you share those details please.
