nxthuan512
How to read/write burst transfer from/to DDR4 using MIG in User interface
I am using the MIG DDR4 controller using User interface setting (Ref. https://www.xilinx.com/content/dam/xilinx/support/documentation/ip_documentation/ultrascale_memory_ip/v1_4/pg150-ultrascale-memory-ip.pdf#nameddest=xDDR3DDR4DesignFlowSteps , page 122)
The interface, however, doesn't support burst count signals. Is there anyway to have that feature appears in the User interface?
lettertu
Hi @nxthuan512
Would you like to use AXI4 interface in your design?
Burst transaction is supported by the AXI4 interface.
nxthuan512
Hi, thank for your reply.
My current design interface is based on Altera Avalon and it is much easy to convert Avalon to MIG user interface.
I also tried to use AMM Master bridge (https://www.xilinx.com/support/documentation/ip_documentation/amm_axi_bridge/v1_0/pg287-amm-axi-bridge.pdf) that converts Avalon to AXI. However, the bridge doesn't support partial/sparse byte-enables except for last beat.
