Anonymous
Not applicable
How to support LRDIMM?
   Well,I want to use LR-DIMM for our project, and I can not find MIG support for Micron's MT36KSZF2G72LDZ.
 So ,who can give me some help  ,   thanks!!!
Re: How to support LRDIMM?
Hello
I am with Inphi and manage the LRDIMM program. We supply the memory buffer to Micron, critical component of LRDIMM. If you are trying to make LRDIMM work with a you own controller, you will need to follow proper initialization sequence.
But some additional detail will help. Please send me an note at skuppahalli@inphi.com and we can have a discussion. I should be able to send you an application note if needed.
Anonymous
Not applicable
Hello
  I have some questions about IMB registers set , when I completed the IMB to sdram initial processing.(according to the  LRDIMM_init_iMB02_GS02B_0v4.pdf  document) I have a problem during RDLVL processing, (send the pattern data and read back the wrong patterns ) of  the MC to IMB initial processing ,so I need some help.
thanks
