chldlrtjd
I have a question about real DDR3 memory bandwidth in Kintex and Zynq.
Dear Xilinx experts.
Thank you very much for your excellent best supports.
Our FPGA receives data from 3.125Gbps serial link (GTX).
I guess the data rate and datapath are 32 bits @ 62.5 Mhz.
I would like to store/read the data stream into/from DDR3 memory simultaneously.
Is it possible in Kintex and Zynq ?
How can I implement it?
Should I use DMA?
Thank you very much.
rpr
Hi @chldlrtjd
Are you looking for Kintex and Zynq ultrascale or 7 series? Xilinx Provides memory interface generator over Kintex and Zynq devices and also PS DDR interface over Zynq.
PG150 - UltraScale Memory Product Guide
UG586 - 7 Series FPGAs Memory Interface Solution User Guide
UG1085 - Zynq UltraScale+ Device Technical Reference Manual
UG585 - Zynq-7000 SoC Technical Reference Manual
Vivado provides block design, create design and you can add IPs as per your requirement and validate the design.
You can implement the design.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
rpr
Hi @chldlrtjd
Pratap
u4223374
Advisor
Advisor
@chldlrtjd That should be easy, depending on how you configure the RAM. For a Zynq 7000, you can have 32-bit RAM at 1066MT/s = 34133Mbit/s. You never get the full bandwidth, but if you do linear reads/writes to RAM and the CPU isn't occupying too much bandwidth then getting >80% of the full bandwidth should be quite achievable.
The trick here will be appropriate buffering. You don't want to be writing one byte, reading one byte, writing one byte, reading one byte, etc. Much better to write 1KB, read 1KB, write 1KB, read 1KB, etc.
DDRx memory (all of them, from DDR to DDR4) is single-access, you either read or write, never both (strictly speaking) simultaneously.
But....
As @u4223374 mentions, the best data rates are obtained when you transfer blocks, so with the proper use of buffering and DMA functions you can achieve high and (apparently) simultaneous r/w operations. Note that buffering causes latency and desynchronizes read and written data. Also note that:
read data rate + write data rate ≤ DDR data rate
chldlrtjd
Dear Pratap, u4223374, archangel-lightworks
Thank you very much for your precious answer.
Ick-Sung Choi.
