Ankush
Is it possible to connect 32bit DDR at PL side on ZCU104 Board?
rpr
Hi @Ankush
Yes PL MIG interface supports 32bit interface.
ZCU104 provides SODIMM, you can configure as per your requirement.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
Ankush
How to configure ZCU104 SODIMM to use 32bit DDR?
rpr
Hi @Ankush
Go to the basic tab then Configure data width to 32.
Pratap
Ankush
Hi Pratap,
On ZCU104 Eval board, The DDR related HP bank pins are connected to SODIMM Socket.
This SODIMM Socket is to insert 64bit DDR chip.
So even if we configure and do assignment for 32bit DDR inside the FPGA, Is it possible to connect the 32bit DDR memory on ZCU104 Board SODIMM socket? If yes what will be the pin assignment for 32bit DDR? (In ZCU104 pin assignment for 64bit DDR is given ).
Ankush
rpr
Hi @Ankush
Configure core to 32 bit width and try using first 32 pins of 64 bit xdc.
Pratap
Ankush
Will it be possible to connect 32 bit DDR device to the SODIMM socket of 64bit on ZCU104 board?
