dkartis2
LPDDR2 with LVDS_25 Clock
The constraints file generated from the MIG sets all of the pins, including the clock, to HSUL_12 or DIFF_HSUL_12. With inputs, the clock doesn't have to be 1.2 V, but I am unsure if a clock made for LVDS_25 would be alright. The following AR seems to suggest this functionality is alright from the FPGA's perspective. If I get this clock, then I'd set the pin to LVDS_25, but would the MIG still function?
AR# 43989
vsrunga
@dkartis2
I assume you are referrinf MIg system clock, if yes you can use LVDS_25, please refer below AR for more details
http://www.xilinx.com/support/answers/40603.html
Hope this helps
-Vanitha
vsrunga
@dkartis2
Hope this helps
-Vanitha
dkartis2
Exactly what I needed, thanks
