darwineg
MIG DDR2/DDR3 PCB layout solution for single 512Mb ( 32M x 16 )
Does Xilinx or anyone out there have an actual PCB layout solution for a Spartan-6 (XC6SLX16-3FTG256C) MIG to a 32Mx16 DDR2 or DDR3 device. The PCB layout will want to run at a maximum of 800MB/s. My requirement is for a single Memory device. If possible, the solution would be implemented on a 6 layer PCB, but more layers, if required, would be acceptable. I have my design set to use the MIG for bank 3.
Thank you.
Darwineg
kshimizu
Hello @darwineg ,
DUG388 mentions the PCB layout for Spartan-6 device.  I hope it would be helpful.
Best regards,
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
kren
You can refer to our evaluation board SP605 and find the schematic and board files at  https://www.xilinx.com/products/boards-and-kits/ek-s6-sp605-g.html#overview
-----------------------------------------------------Please don't forget to give kudos or accept as solution if information provided is helpful.---------------------------------------------------------------------
