mckr
MIG Example Design Simulation
Hello. I am new in using MIG so I want to see the results of the example design simulation. For this, I have formed MIG core as in UG 586. Then, I have opened the Example Project . And I clicked Run simulation button. However, the stimulus on the screen is different than the UG 586. In my screen, only clock is changing there is no change in address or data .
I think that traffic generator is not working.
What is wrong with my simulation ?
Thanks in Advance
yenigal
How much time did you simulate the core.
Did you get simulation successful message in the console.
The data transmission starts after calibration done and it takes around 50-80us for calibration to be completed.
Satish
yenigal
Satish
vsrunga
The stimulus on the screen is different than the UG 586
--Can you upload your screen and refrer figure number from UG586 along with version document?
The first stage in simulation would be initialization and then calibration  during which all the signals do toggle but not frequent enough.
I would suggest you to check the transcript messages to know what is happening, you will see text like initialization done, write levelling done, read levelling  done and at last test passed
To complete all these stages you need to wait for 10 to 20 min which is 50 us simulation time.
Hope this helps
Vanitha
mckr
thanks to  @yenigal and @vsrunga. After the 107usecond simulation will start to read/write the data to ddr3.
Just one question more, Are there any way the simulation without calibration stages?
Thanks a lot....
yenigal
No we cannot skip calibration even in simulation.
Satish
