sriramv90
MIG PHY read data valid
I'm using a MIG PHY only design with a custom controller. The design works mostly but crashes due to no read data valid signal from the PHY when there is a continuous read from the application. This crash varies between 10 to 50 reads. Please suggest as to why this behavior is seen.
I'm using MIG 7 series with Vivado 2015.2 for Zynq ZC706 board. Please advise.
Sriram
sriramv90
After a bit of searching, we found that this could be due to missing periodic reads. Could anyone explain what periodic logic does and is it necessary for all phy only designs. Please advise. Thanks in advance.
-Sriram
vsrunga
@sriramv90
Hi please check below AR for details on periodic read,
http://www.xilinx.com/support/answers/43344.html
It is necesary to issue periodic read for phy only design as well. You can refer below AR for more deatils
http://www.xilinx.com/Attachment/Xilinx_Answer_51204.pdf
Hope this helps
-Vanitha
sriramv90
Thank you for your response. I have gone through the AR on periodic read. Periodic read is to send read commands if there are no read requests till 1us. Is it enough to implement a simple logic such as this:
if(read_req_received){
reset clock_count;
else if(clock_count == PERIODIC_READ_COUNT) {
send_read;
reset clock_cnt;
block any request till read_ack;
else if(clock_count < PERIODIC_READ_COUNT) {
increment clock_count;
-Sriram.
