MIG UI clock doesnt seem correct
I have a MIG Artix DDR2 design. I have a mem clock of 320MHz and that should give a UI clock of 80 MHz. But I think that I am actually getting 40MHz. If I look at the MMCM that is generated in MIG, the UI clock comes from CLKFBOUT. The parameters are
CLK in period 12.5ns = 80MHz
CLKFBOUT MULT = 15
CLKOUT0 DIVIDE = 30
Does this not give 40MHz?
UI clock freqeuncy should be (Clk input frequency / DIVCLK_DIVIDE).
-----------------------------------------------------Please don't forget to give kudos or accept as solution if information provided is helpful.---------------------------------------------------------------------
