whitleda
MIG UltraScale sys_rst
Why does the MIG UltraScale (Block Design) LOC sys_rst in the auto generated XDC file?
Is this suggesting that this input must be in the Adress/Ctrl-2 Byte Block?
Tags (2)
vsrunga
I guess IBUF is generated ir-respective of the sys reset pin assignment which is planned for fix, but MIG XDC includes sys_rst pin in the generated xdc even though you have unplaced the pin in MIG pin planner?
