MIG constrain error :can't find object
The error is disappeared after i add an new */*/ hierarchy path before the MIG xdc constrain line . how to let MIG add the hierarch path automatic? The mig ip is instantied under top level.
set_max_delay 5.0 -datapath_only -from [get_pins */*/*/u_ddr_cal_addr_decode/io_ready_lvl_reg/C] -to [get_pins */u_io_ready_lvl_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 5.0 -datapath_only -from [get_pins */*/*/*/*/u_ddr_cal_addr_decode/io_ready_lvl_reg/C] -to [get_pins */*/*/u_io_ready_lvl_sync/SYNC[*].sync_reg_reg[0]/D]
Hi @m006
If you add IP XCI to the project then the constraints should be read by the tool correctly.
Can you share the IP XCI?
Deepika.
Hi @m006,
I have read your recent thread : https://forums.xilinx.com/t5/Implementation/CRITICAL-WARNING-Project-1-840/td-p/800344
Are you sure that you are using xci or xcix for the IPs?
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
it is two issues.
I use dcp file(read_checkpoint cmd)
Hi @m006
When you use IP DCP and XDC files, the constraints will not be evaluated properly. This is the reason we recommend using IP XCI file instead.
Deepika.
Hey @m006,
The correct flow for reading in an IP DCP (for non-project mode) is to use: read_ip ip_name.xci. If a DCP/generated RTL exist, then it will they will be pulled in as well. Top level constraints can only be applied properly to an IP through an XCI file. read_checkpoint should only be used with top level DCP's and not standalone IP DCP's.
For more information on this flow, please look into https://www.xilinx.com/support/answers/69690.html
Cory
