Voyager
Voyager
MIG constrain error :can't find object
The error is disappeared after i add an new */*/ hierarchy path before the MIG xdc constrain line . how to let MIG add the hierarch path automatic? The mig ip is instantied under top level.
set_max_delay 5.0 -datapath_only -from [get_pins */*/*/u_ddr_cal_addr_decode/io_ready_lvl_reg/C] -to [get_pins */u_io_ready_lvl_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 5.0 -datapath_only -from [get_pins */*/*/*/*/u_ddr_cal_addr_decode/io_ready_lvl_reg/C] -to [get_pins */*/*/u_io_ready_lvl_sync/SYNC[*].sync_reg_reg[0]/D]
Hi @m006
If you add IP XCI to the project then the constraints should be read by the tool correctly.
Can you share the IP XCI?
Deepika.
Hi @m006,
I have read your recent thread : https://forums.xilinx.com/t5/Implementation/CRITICAL-WARNING-Project-1-840/td-p/800344
Are you sure that you are using xci or xcix for the IPs?
FPGA enthusiast!
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer solved your problem.
Voyager
Voyager
it is two issues.
I use dcp file(read_checkpoint cmd)
Hi @m006
When you use IP DCP and XDC files, the constraints will not be evaluated properly. This is the reason we recommend using IP XCI file instead.
Deepika.
Hey @m006,
The correct flow for reading in an IP DCP (for non-project mode) is to use: read_ip ip_name.xci. If a DCP/generated RTL exist, then it will they will be pulled in as well. Top level constraints can only be applied properly to an IP through an XCI file. read_checkpoint should only be used with top level DCP's and not standalone IP DCP's.
For more information on this flow, please look into https://www.xilinx.com/support/answers/69690.html
Cory
