MIG output clocks using for driving other logics
Could I use MIG IP clock outputs ( ui_clk ) to drive the other logics ( as AXI-Stream and AXI-Lite clocks )  ?  Is MIG IP needed to be initialization in SW ? or directly begin to execution  ?
Best Regards,
Tags (4)
If you look at the MIG example_design this ui_clk is used to drive the traffic_gen that R/W DDR via MIG core. So it should be possible to use in other parts of the logic that drives data/reads from the MIG core.
You much check the init_calibration_complete status, out from the MIG core. If it is high then only begin operation with the MIG.
FPGA enthusiast!
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer solved your problem.
FPGA enthusiast!
Thank you @dpaul24
I am using ui_clk '  output of MIG IP, to drive the other logics. Even I have used internal PLL of MIG IP to produce some other clocks. I have checked clocks are properly produced.
