MIG output clocks using for driving other logics
Could I use MIG IP clock outputs ( ui_clk ) to drive the other logics ( as AXI-Stream and AXI-Lite clocks )  ?  Is MIG IP needed to be initialization in SW ? or directly begin to execution  ?
Best Regards,
Tags (4)
If you look at the MIG example_design this ui_clk is used to drive the traffic_gen that R/W DDR via MIG core. So it should be possible to use in other parts of the logic that drives data/reads from the MIG core.
You much check the init_calibration_complete status, out from the MIG core. If it is high then only begin operation with the MIG.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Thank you @dpaul24
I am using ui_clk '  output of MIG IP, to drive the other logics. Even I have used internal PLL of MIG IP to produce some other clocks. I have checked clocks are properly produced.
