balanga
MIG
Hello
I need to use 4 GB DDR3 in Zynq 7000 for PL part.
but the PL doesn't support more than 2GB DDR3.
can i use 2 controller in MIG?
and if I use 2 controller how many pin increase?
can i use 2 controler and just one pin added in adress pin?
please guide me
thanks
rpr
Hi @balanga
MIG supports 4GB if GUI memory part list is not available with 4GB part then use the custom part option. You can change the address/column/row widths.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
