MIG7 unexpected behavior on custom board Kintex7
I designed a telecommunication purpose custom Kintex 7 board. Everything works fine expect the SO-DIMM DDR3 interface.
I used the Vivado MIG to generate the interface with the following parameters:
Vivado Project Options:
Target Device : xc7k160t-ffg676
Speed Grade : -2
HDL : vhdl
Synthesis Tool : VIVADO
MIG Output Options:
Module Name : mig_7series_0
No of Controllers : 1
FPGA Options:
System Clock Type : Differential
Reference Clock Type : Use System Clock
Debug Port : ON
Internal Vref : disabled
IO Power Reduction : OFF
XADC instantiation in MIG : Enabled
Extended FPGA Options:
DCI for DQ,DQS/DQS#,DM : enabled
Internal Termination (HR Banks) : 50 Ohms
/* Controller 0 */
Controller Options :
Memory : DDR3_SDRAM
Interface : NATIVE
Design Clock Frequency : 2500 ps (400.00 MHz)
Phy to Controller Clock Ratio : 4:1
Input Clock Period : 5000 ps
CLKFBOUT_MULT (PLL) : 4
DIVCLK_DIVIDE (PLL) : 1
VCC_AUX IO : 1.8V
Memory Type : SODIMMs
Memory Part : MT8KTF51264HZ-1G9
Equivalent Part(s) : --
Data Width : 64
ECC : Disabled
Data Mask : disabled
ORDERING : Strict
AXI Parameters :
Data Width : 512
Arbitration Scheme : RD_PRI_REG
Narrow Burst Support : 0
ID Width : 4
Memory Options:
Burst Length (MR0[1:0]) : 8 - Fixed
Read Burst Type (MR0[3]) : Sequential
CAS Latency (MR0[6:4]) : 6
Output Drive Strength (MR1[5,1]) : RZQ/6
Controller CS option : Enable
Rtt_NOM - ODT (MR1[9,6,2]) : RZQ/6
Rtt_WR - Dynamic ODT (MR2[10:9]) : Dynamic ODT off
Memory Address Mapping : ROW_BANK_COLUMN
Bank Selections:
System_Clock:
SignalName: sys_clk_p/n
PadLocation: AA10/AB10(CC_P/N) Bank: 33
System_Control:
SignalName: sys_rst
PadLocation: D25(DQS) Bank: 14
SignalName: init_calib_complete
PadLocation: D15 Bank: 15
SignalName: tg_compare_error
PadLocation: G26 Bank: 14
Module: MT8KTF51264HZ-1G9P1
Oscilattor: SI545 200MHz
The traces were routed with 50 Ohm impedance because its only a 6 layer board.
VRN/VRP Resistor: 100Ohm
In the ILA I get the following signals:
(The forum didnt let me post the exported ILA)
dqsfound_start = 1 dqsfound_err = 1
rdlvl_start = 0 rdlvl_done = 10
oclkdelay_calib_start = 0 oclkdelay_calib_done = 1
The data and read offset didnt count at all.
As far as i understand I shouldnt get this combination of signals. I started with probeing the power supplies and the DQS signals on the so-dimm module. The 1.5V, 0.75V had noise below 30mVpp. The signal integrity was similar all across on the strobes i could probe (Sorry for the image quality).
I have no idea how to continue debuging of the interface. Could you help me in the debuging?
Bests,
Balázs
You can refer to "Debugging PHASER_IN DQSFOUND Calibration Failures" section in ug586.
