Memory Interface Generator (MIG) with the Evaluation Board KC705
I'd like to receive some advise in what I'm trying to do, of course if you can: I need to adapt the DDR3 read and write operations  to another design, basically I do not need a random pattern generator, instead I need to use own data for example data from other application. I've thought to cut the traffic generator but it is a large code. Some advises related to that?
thank you so much
@jose09621,
I mean, I first need to study the code of the pattern generator and next create my state machine with that behavior.
Not necessary. But if you want to study & have time, go ahead, it would be good.
Do you know how to write the code for a counter and simple state machine?
If yes, then your state machine will just contain an incrementing or decrementing counter and it should drive the MIG i/f signals. You data generator is done.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
@jose09621,
It depends on your RTL skills, it is not that difficult in my opinion. I did it some years ago.
Just connect your own data generator state-machine to the MIG interface and you are good to go.
I'm sorry I'm new in this, I appreciate your help.
And does my state machine should work as the pattern generator does? I mean, I first need to study the code of the pattern generator and next create my state machine with that behavior.
thanks
@jose09621,
thanks for your answers I'll try it and tell you how it worked
