mkachar
Memory Interface Generator
Failed to generate IP 'mig_7series_0'. Failed to generate 'Custom UI' outputs:
I recently face this issue on my Ubuntu 18.04LTS OS, while trying to generate the MIG IP core.
I wanted to tweak around the MIG GUI so double clicked on the interface, to get this error message.
The GUI showed up only during the first instance run of the IP, but i did not complete. I had to cancel the run as it took way too much time to generate the core IP. After which i am facing this issue ever since.
I tried creating block interface and adding it to my project, but once i run block automation. I get back the same message.
Can anyone help me with this.
Thank you
kren
What's the Vivado version? You can refer to ug973 to find out the supported operating system.
-----------------------------------------------------Please don't forget to give kudos or accept as solution if information provided is helpful.---------------------------------------------------------------------
