Memory signal group assignment
Hi all,
I have a Vivado project with a XCKU5P-1FFVB676 and four 16bits DDR3 Modules. When it comes to assign the pinout, I've done my first two DDR modules as follow, so the byte 0 group has the DQ0:
Now, for the other two moduldes, I've done as follow:
Is this OK? As you can see the byte 0 has DQ[24-31] and Address/Ctrl remains the same as the first two modules. Vivado didn't complain. I've done it like this because it would be easier to do the pcb routing.
Thanks in advance.
回复: Memory signal group assignment
The pin assignments are good and you can go ahead with your design.
